Parduodu:2000-2005 Honda S2000 Air Pump Simulator
This electronic module simulates the existence of a Honda S2000 air pump system. If the air pump system is defective or deleted, installing this simulator will eliminate all air pump system Check Engine Light (CEL) codes : P1410, P1415, P1416, P0410, and P0411. This device will work on both USDM and Canadian-Spec Honda S2000's.
http://www.izzera...hWcl23E43Q
Karlos prisegti paveiksliukai:
Redagavo Karlos 2025.06.21 13:10
